Full Production Lifecycle Solutions
Front-end through back-end applications
Scroll horizontally within the table below to reveal more information.
Application
Measuring Challenge
Solution
Front End
Wafer Manufacture
A/N Mark width, position, dot diameter, depth
Ingot Diameter
Automated Optical Inspection (AOI)
  • Measure A/N mark width, position, dot diameter, and depth
  • Measure high speed with Stream option
  • Sub-micron accuracy
Laser Scan Micrometer
  • Measure the ingot diameter
  • Non-contact (no scratches, no abrasions)
  • Micron level accuracy
Flattening
Wafer thickness, back surface roughness, groove width, depth, pitch, roughness, scratches and other wafer surface defects
  • Inspect the wafer for scratches and other defects
  • AI Inspect uses machine learning to learn what a defect is
Digital Measuring Gage
  • Measure the wafer thickness
  • Extremely light force (0.01N)
  • Submicron accuracy
Linear Encoder
  • Incorporated into CVD machine
  • Nanometer resolution 8,000 mm/s response speed
Surface Roughness Measuring System
  • Measure the wafer roughness
  • High speed, 80 mm/s
Etching
CVD Equipment Parts: flatness, form analysis, roughness
  • Measure the CVD plate hole locations and diameters
  • Stream can measure the holes very quickly
  • AI Inspect or DDPak can check for debris in the holes
Linear Encoder
VIA Cuts
Hole diameter and position
  • Measure the hold diameters and depth
  • Optional NIR to see through the substrate
QV Apex with Stream
  • Inspect VIA hole diameters
  • Detect defects in VIA holes
Metallization
Etching: electrostatic chuck, silicone ring flatness, cross section, roughness, showerhead nozzle diameter, roundness, position
Sputtering
  • Measure the CVD plate hole locations and diameters, and measure sputtering targets
  • AI Inspect can measure the CVD plate surface for scratches
Coordinate Measuring Machine (CMM)
  • Measure CVD, electrostatic chuck, and silicone ring for flatness
  • World’s most accurate CMM
Contour Measuring System
  • Measure CVD, electrostatic chuck, and silicone ring for surface roughness
Die Sorting
Probe card, IC test socket
Wafer probe, Probe needle
  • Measure the probe card hole diameters and positions
Microscope
  • Measure the probe needle
  • High resolution
  • High quality, high NA optic
Profile Projector
  • Easy to use
  • Low cost of ownership
Back End
Dicing
Cross-section observation, chip thickness, post-dicing back surface burr height
  • Measure the burr after dicing
  • WLI generates a point cloud of tens of thousands of points
Microscope
  • Measure the cross section of the diced IC
  • High resolution
Ultra High Accuracy Linear Gage Probe
  • Measure the IC thickness 0.1 micron accuracy
Bonding
Lead frame width, pitch, height, twisting
Wire loop height
  • Measure lead frame width, pitch, height, twist
  • Measure wire loop height
Microscope
  • High resolution
  • High quality, high NA optics
Packaging
Lead width, pitch, height variation, gap
Solder ball height, diameter, pitch, coplanarity
QV Hyper with WLI
  • Measure lead with, pitch, and height
  • Measure solder ball height, diameter, pitch, coplanarity
  • CPS measures Z points using a chromatic position sensor
Microscope
  • Measure the test socket pin height
  • High resolution High quality, high NA optics
  • Measure lead width, pitch, gap
Ready to Learn More?
