The Mitutoyo SJ-210 Surface Roughness Tester provides accuracy, versatility, portability, user-friendly interface, data management capabilities, and durability, wherever surface roughness measurements are needed. Whether on the shop floor, in the field, or a laboratory, Mitutoyo now offers four different types of SJ-210 promotional packages to better suit your surface roughness measurement needs.
For detailed information on the Mitutoyo SJ-210, complete the form below to be contacted by either phone or email.
The Surftest SJ-210 surface roughness measuring instrument has a 2.4 inch back-lit built-in color LCD display for users to view surface roughness waveforms. This display also provides sectional calculation results, assessed profiles, load curves, and amplitude distribution curves, along with measurement results. It’s versatile, capturing measurements in any orientation, including vertical and upside-down. Optional accessories, like a height gage adapter, column stand or magnetic base adapter, enhance the SJ-210’s efficiency for measurements in different situations.
- Built-in 2.4-inch color graphic, back-lit LCD display provides excellent readability, improved visibility and is easy-to-use in dark environments.
- Can perform measurements in any orientation, including vertical and upside down, on both the X- and Y-axes.
- The built-in battery allows approximately 1,000 measurements on a full charge (4 hours charging time).
- Performs roughness analysis conforming to international standards JIS ’82 / JIS ’94 / JIS ’01 / ISO ’97 /ANSI/VDA.
- Optional MicroSD card can store up to 500 measurement conditions, 10000 measurement results and 500 image data.
- Function restriction feature locks conditions to prevent erroneous measurements if settings are accidentally changed.
Easy, Accurate Measurements You Can Trust, Anywhere
The SJ-210 can measure a wide range of surface textures, including roughness, and primary profile, on various materials such as metals, plastics, ceramics, and composites with high accuracy in a variety of industries. Designed to be lightweight and portable, the SJ-210 performs surface roughness measurements conveniently in different locations, including manufacturing facilities, laboratories, and field environments. Its compact size and battery-powered operation enhance flexibility and usability. Its advanced technology and calibration ensure consistent and repeatable results, which are crucial for quality control and inspection applications.
Calibration Package
- SJ-210 4MN (STANDARD DRIVE UNIT) INCH/MM
- Calibration Specimen fee
- FREE EXTRA DETECTOR
- eLearning Course
Includes a spare detector and a certified specimen with traceability so it is ready to be used right out of the box after performing a calibration.
Data Collection Package
- U-WAVE TRANSMITTER
- U-WAVE RECEIVER
- U-WAVE connecting cable
- eLearning Course
Includes components to make data transmission wireless with one-touch operation to remotely enter the calculation results (values) into commercial spreadsheet software on a PC.
Height Gage Package
- Digimatic Height Gage (HDSH18″ CX)
- Height Gage Adapter (INCH)
- eLearning Course
Included height gage (new HDS Series) and adapter enables vertical or horizontal mounting of the drive unit for measuring deep bores or different steps and heights on a workpiece with better stability.
Manual Column Stand Package
- Column Stand for SJ-210/310/410
- Magnetic Stand Adaptor (8mm DIA)
- eLearning Course
Included stand and adaptor allows for better mounting stability for more accurate, precise, and repeatable measurements along with smoother, more precise movements for easier positioning.
