The benefits of the Mitutoyo LH600F Height Gage include:
- New 8.4-inch color LCD touchscreen display rotates and swivels for easy access and use from any orientation.
- Simple, straightforward keys with icons allow the user to find the required basic and advanced measurement operations at a glance.
- Automatic scale check leads the user through the menu to set the scale origin and run the automated procedure to check the scale for contamination at start-up.
- A calibration reminder notification will show on the touchscreen before the calibration due date set by the user.
Easy to Use
The LH-600F/FG linear height gage features a large 8.4-inch color touchscreen with simple, straightforward keys, making this height gage easier to use – even for beginners. The LCD touchscreen rotates and swivels for access to the display while measuring from almost any orientation, and many different operations are easily controlled on the touchscreen, even while wearing gloves. The display shows each measurement step – and measurement guidance is available in 21 different languages. All basic measurements are also displayed as icons on large buttons that are easy to see and use, even in a factory setting.
Accuracy & Versatility
The Mitutoyo LH-600F/FG continues with the precision and accuracy expected from a Mitutoyo linear height gage, achieving a best-in-class accuracy of ±(1.1+0.6L/600)µm with 0.1µm/0.5µm resolution/repeatability. Beyond being one of the most accurate height gages available, the LH-600F has the ability to take many different, various measurements in a single unit with for even better usability and efficiency. Multiple optional probes and switchable probe positions provide excellent perpendicularity and straightness measurements along with the ability to measure hole depths and other hard-to-measure dimensions.
The Best in Linear Height Measurements
The latest Mitutoyo Linear Height Measurement System, the LH-600F, offers best-in-class accuracy due to its high-precision scale unit and guiding mechanism. It now features a user-friendly touchscreen interface for effortless operation and has an adjustable display for usage from both front and rear. Furthermore, it provides advanced output options, such as Digimatic output for direct data transfer to Excel or SPC software, wired or wirelessly, while also retaining USB and RS232C output capabilities.
The many different features and functions on the LH600F make the unit extremely versatile, allowing for various measurements to be taken in just one unit. The pre-placement function makes setting up work pieces for measurement much faster, and you can check perpendicularity and straightness measurement results in real time during measurements. A new graph creation feature also allows you to easily see trends of the measurement results in a graph.
Better Usability
- Large color touchscreen is rotatable and adjustable for use in both front and rear orientations
- Motorized capabilities provide better repeatability and reproducibility for improved quality control
- Built-in temperature compensation allows for more accurate measurements without a temperature-controlled room
Various Output Options
- New Digimatic output sends data directly to Excel or SPC software
- New optional footswitch is available for hands-free repeat measuring of volume parts
- Data output can be wired or wireless
Part Program Measurement
- Easily access and use the Create, Run, Edit and View part program functions
- Display all results for all executions or the result for a specific execution
- Use a USB memory device to copy part programs to other devices if needed
